CV Joints
CV Joints
How do I know if my CV Joints are bad? Every search I have made so far gives me a 'How To' for Installing. I just wanna know if they are bad.
Thanks,
Thomas
Thanks,
Thomas
Re: CV Joints (mace232)
Two ways to know:
1) If they click, or make any sort of noise, while driving or turning, then they are bad.
2) If you visually inspect them, see if they are busted or leaking. That would also mean they are bad.
Replace those bad boys!
Re: CV Joints (94HybridEX)
just look at the boot closest to the wheel, those are the most notorious for busting...if there is grease slung all over the place, either replace the boot(unless the bearings are dry)....if you waited too long and hear a "clicking" sound while turning and accelerating, then you got a 2 hour CV axle job, buddy...have fun
the replacement is really simple, but time consuming....just unbolt the hub, steering knuckle, and part of the lower strut, and try to manuever the axle's hub out, and pull it out the tranny...not too hard, but it's time consuming...late
Re: CV Joints (ViZ)
mine knock when i turn and sometimes you can feal it in the steering wheel
Re: CV Joints (owen_the_soyboy)
i meant when they go bad, ive had it even knock while going straight but i never had one leave me stranded... i need to invest in a aftermarket set because i go through these things way to fast
Spry
11
06-08-2004 08:33 PM
94FrstWhiteSi
10-20-2002 07:04 PM
