ctr tranny?
ctr tranny?
I was told i had a type r b16 tranny on my car from the previous owner, is there an indication to identify it externally to see if its actually true, because im in need of new clutch but not sure what tranny it is because it may also be a b16a tranny.....do both trannys use the same clutch?
Re: ctr tranny? (hectic57)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hectic57 »</TD></TR><TR><TD CLASS="quote">sorry for being a noob...what stamp,did you mean the engine code?its a b16a</TD></TR></TABLE>
not the engine code... there should be a black stamp on the tranny case... should start with a letter and end with a number. my b16a2 tranny is a S4... for an example. its on the top and faces you.... you might need to clean the tranny to see it.
Re: ctr tranny? (steverson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steverson »</TD></TR><TR><TD CLASS="quote">the clutch should be the same for all b series motors.. </TD></TR></TABLE>
Not quite true. Early (1988-1991) cable B-series transmissions use a smaller input shaft spline. But if you stick with anything 1992 and later, they are all the same.
HRD PKR
Re: ctr tranny? (StorminMatt)
If you have a type r trans its either the b16b or b18c transmission. Does your transmission have and lsd?
92-00 B-series hydro clutch's are the same
JDM B16A
04-23-2006 01:50 PM
