Crank Position Sensor on a 96-98 civic ex.....where is it?
Old 01-14-2003, 09:24 AM
who00knows's Avatar
Default Crank Position Sensor on a 96-98 civic ex.....where is it?
Is it located in the distributor or the crank>>>>>
Old 01-14-2003, 09:30 AM
cnk600's Avatar
Default Re: Crank Position Sensor on a 96-98 civic ex.....where is it? (who00knows)
the crank position sensor is located at the crankshaft. you can access it by removing the timing cover, crank pulley, timing belt. The crank gear is also the sensors reference.
Old 01-14-2003, 10:32 AM
EE_Chris's Avatar
Default Re: Crank Position Sensor on a 96-98 civic ex.....where is it? (cnk600)
That would be the Crankshaft Fluctuation Sensor you are referring to. The CKP sensor is inside the distributor along with the TDC and CYL sensors.
Natie Barnard
Honda CR-V & Element
01-16-2019 06:38 AM
kndj30
Honda Civic (2001 - 2005)
02-11-2010 03:58 AM
2000siturboR
11-06-2009 03:29 PM
xwhitchx
05-27-2009 05:55 PM
prjctCIVIC
08-26-2002 08:34 PM
Quick Reply: Crank Position Sensor on a 96-98 civic ex.....where is it?
