Crank Position Sensor on a 96-98 civic ex.....where is it?
Re: Crank Position Sensor on a 96-98 civic ex.....where is it? (who00knows)
the crank position sensor is located at the crankshaft. you can access it by removing the timing cover, crank pulley, timing belt. The crank gear is also the sensors reference.
Re: Crank Position Sensor on a 96-98 civic ex.....where is it? (cnk600)
That would be the Crankshaft Fluctuation Sensor you are referring to. The CKP sensor is inside the distributor along with the TDC and CYL sensors.
xwhitchx
05-27-2009 05:55 PM
