couple quick questions
at the jetties fishin'
how do you get an old broken wheel stud out (and in) off the hub assembly on 92-95 civics??
do you just beat it out with a hammer and then zip the new one in using a lugnut and zip gun??
also, anyone know where I can order a rebuild kit for a power steering rack as well??
Re: (vanste)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vanste »</TD></TR><TR><TD CLASS="quote">im pretty sure your going to have to press the hub out in order to take the stud out... </TD></TR></TABLE>
anyone know for sure if this has to be done or not?? going to take a better look tonight when I get home.
Re: (92VXeg)
when you say pressed, you mean the stud being pressed out of the hub or that the hub has to be pressed out befor you can remove the studs at which point you'd do the bearings while you're in there??
the hubs are what needs to be pressed out. The bearings are just a hugh suggestion since they might not be in the best reusable condition as needed. They will be put in when the hub has been pressed out.
