a couple ej questions
Hey guys, couple questions. First, are the tail light bulb harnesses the same on all 96-00 year civic coupes? And the front suspension forks that connect the strut to the lca are those all the same between 96-00 2dr and/or 4dr?
Ek Forever y0!
Re: a couple ej questions (EJ8 Kenobi)
The suspensions are all the same except for the ex/si getting different front LCA's for the sway bars.
The tail-light harnesses are differen't between 96-98 and 99-00. The turn signal bulb is differen't.
It's still compatible between generations, it's just hard to find the amber bulb for the 96-98 harness. I usually find them at autozone.
Re: a couple ej questions (ek forever guy)
Thanks man,
So if I have a 2000ex my front suspension forks will not be compatible with say a 97 dx? but it would a 97 ex.
the sway bar mounts to the forks? or are you say that the LCA's are not the same but the forks don't matter
Ek Forever y0!
Doh, nvmd, i thought you said Lcas.
No, all the forks are the same I belive.
Ex civic
http://www.hondaautomotivepart...81%29
Dx/cx civic
Same part #
Ex civic
Dx/cx civic
Same part #
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">The suspensions are all the same except for the ex/si getting different front LCA's for the sway bars.
It's still compatible between generations, it's just hard to find the amber bulb for the 96-98 harness. I usually find them at autozone.</TD></TR></TABLE>
To clarify:
The '96-'98 coupe taillight harness IS NOT the same as the '99-'00 coupe taillight harness. They are interchangeable, but if you have a '96-'98 harness on a '99-'00 taillight, you will likley have trouble finding the amber bulb to fit in the '96-'98 turn signal socket on the harness.
To clarify:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">They would be compatible, you just wouldn't have mounting holes for a sway bar.</TD></TR></TABLE>
sway bars mount to the LCA not the suspension forks
Ek Forever y0!
Re: a couple ej questions (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 »</TD></TR><TR><TD CLASS="quote">
sway bars mount to the LCA not the suspension forks </TD></TR></TABLE>
Umm, I already corrected myself. Thanks Captain Obvious. You saved the day again with another useful post.
eklum
Northern California (Sales)
01-03-2007 03:53 PM
EL Vap133
15
04-14-2005 05:26 PM
