coolant temp switch/and sensor
they both have the same plug, where do the two go? the switch goes to the thermostat housing right?....and where is the other one located?
Re: coolant temp switch/and sensor
The two-wire coolant temperature switch is located in the thermostat housing, whereas the two-wire coolant temperature sensor is located below the distributor. Two coolant temperature measuring devices are located under the distributor -- the one-wire coolant temperature sending unit for the dash gauge and two wire coolant temperature sensor. The latter sensor is closer to the radiator than is the sending unit.
Old thread i know, but this is exactly the info im needing.
92 eg b7/z6 swap. My rad fan WILL come on if i jump the temp switch, my gauge works, but my fan doesnt turn on by itself.
Could the coolant temp switch AND sensor both cause this? In other words, if either one fails, the fan wont work automatically?
ok, could the ECT sensor under the dizzy cause shitty gas milage if its goin bad?
The IAT colors are grn/wht, red/ylw...i believe, i may have gotten that mixed around but the main colors and red and green.
My gas gauge seems to be on a "float" type level indicator, which doesnt seem right since my last eg never did this. Just last night i filled up, hit the F and i'de make a turn to get onto the freeway and it would drop to 3/4 of a tank and move around anywhere from 1/2 back to F.
I have the smell of fuel in the engine bay, when i changed the oil, i noticed a fuel smell in the oil as well.
CEL 10, IAT sensor, i bought a brand new one from Honda and i still get the same code. Found out later that my IACV and IAT sensor plugs were switched, i corrected that and i still got the code.
bad wiring can cause CELs too, sometimes its not just the sensor itself
Dont get me wrong, the car runs like a champ, it idles around 1000-1500rpm right now tho. I have an open vac hole from the back of the IM to the evap canister, when i plug in the vac line, or plug off the open nipple, the idle goes to below 500rpm and eventually dies.
My throttle cable seems to have a litttle bit of play in it between the TB and mounting bracket for throttle cable. I think my idle screw was messed with a little bit but im not sure. It looks like the idle screw was screwed UP, give the cable some slack.
you got all kinds of stuff going on.
1. all obd1 ecus have the same pinout
2. sounds like you need to adjust the base idle. you shouldnt need to create a vac leak to keep the car running, sounds like iacv isnt working or base idle is wrong
3. i dont think a little slack is a problem, again check idle screw.
The gas milage and idle are the problems, im sure the p28 will help the matter, i also need to see if all my o-rings are intact on my injectors.
I'll clean out the IACV when i get home. I need to see a picture of some wiring for a b7 intake manifold, i need to see the colors of the IAT sensor wires and the IACV wires.
http://www.wonderbart.com/images/08/...ine_wiring.gif
looks like iacv is black/yellow & blue/yellow. iat is red/yellow & green/white
Ignore the ugly wiring, this is how it WAS...notice that the red/ylw and grn/wht are NOT going to the IAT..it was leading to the IACV. I've cleaned up the wiring and fixed the connectors so here is the old pic.
mon2mon2
01-17-2022 06:49 PM
