Coolant and oil dont mix well
LS Vtec Built bottom end golden eagle head gasket coolant mixing with oil 140 psi across the board...any info helps
Re: Coolant and oil dont mix well
Check for cracks in the head/block also damaged intake manifold gasket. Do a cylinder leakage test, if numbers are okay, do a wet cylinder leakage test, check for bubbles in radiator. If bubbles appear, possible head gasket problem or damaged cylinder.
lsturbo*
05-06-2008 07:18 PM
