Coolant bleeding?
Coolant bleeding?
Do these cars have a bleed screw or certain procedure for bleeding air bubbles out the coolant? Recently did a water pump and noticed the temp level rising past the center mark. Should I just removed the Rad. cap and set the heat to high and hold the rpms up? Or is their a screw some where?
Thanks! Always appreciate the help
Car is a Stock 97 Civic LX
Retired Moderator
Re: Coolant bleeding?
Jack front end up off ground, use ramps, or an inclined driveway
start car, turn heat to full blast
remove cap and fill
rev engine a little while squeezing hose
when coolant gets low, refill and repeat
do this till no more bubbles show up, finished
remove cap and fill
Agreed^^^ that's gonna be the easiest way
Not really all too neccesary to bleed the system, thats why the new water outlets dont have a bleeder screw. The mechanic at honda told me that when I asked him how im suppose to bleed the system. I didnt bleed mine and never had a problem.
as long as your thermostat has a jiggler pin, just fill it up, squeeze the hose and keep adding coolant until it stays at the neck of the radiator. then put a little extra in the resevoir which will draw itself in the next time it cools down.
RDAYA0
05-22-2008 05:33 PM
