connecting the deck
Re: connecting the deck
I had the same probelm, What I did is went to my local Car stero store and ask If I could have the wire color code hook up for my car, and they printed it off and gave it to me For no cost.
I got the same problem. Previous owner was a dumbass and cut the wires, then connected them back with butt connectors. They probably didn't use an adapter harness with the old radio and tried to patch it together for the one it had in it. I'm running dedicated speaker wire when I get a chance to pick it up.
Here's the diagram with wire colors to identify it all. Just print out page 6. Hope it helps ya bud.
http://www.installdr.com/InstallDocs...PDF/466017.pdf
Oh, and if you can remove the harness, either get a good one or solder that one back together with an OEM connector on the end. Then either use heat shrink tubing or liquid electrical tape.
crxaddikt
07-08-2017 07:56 PM
HT Chaplain
Welding / Fabrication
06-14-2010 08:50 AM
thinkbrianthink
03-06-2003 08:52 AM
