Compression test results for my d16y8, input please
#1 = 170
#2 = 160
#3 = 150
#4 = 160
Are these good the engine has 120k on it and i am getting clciking sound from the head. thanks
#2 = 160
#3 = 150
#4 = 160
Re: (gold_ef)
you think so, could there still be a possibility of a bent valve or is a lash adjustment all i really need? im debating on wether to take the head off and just replace a valve or go thru with the adjustment. Im hoping ot have this car running by this Sat
Re: (gold_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold_ef »</TD></TR><TR><TD CLASS="quote">good numbers, you just need to get a valve adjustment done and that should fix it</TD></TR></TABLE>
yeah, those numbers are fine; nothing to worry about. A valve adjustment will certainly help, but it's nothing urgent.
Re: (dryeager)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dryeager »</TD></TR><TR><TD CLASS="quote">Is there a how to available on adjusting the valves?</TD></TR></TABLE>
I know there is - I saw it a little while ago, but I forgot where. A few minutes of searching will probably get you something.
Re: (gold_ef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold_ef »</TD></TR><TR><TD CLASS="quote">might as well try the easy one first and do a valve lash adjustment, it only takes 10 minutes to do, it might just fix it</TD></TR></TABLE>
thanks, I was going to do it today but i got caught up at the dealership(even my co-workers said valve lash adjust too) so i am going to do it tomorrow and hopefully it works, thanks for all the help.
and the clicking sound is really really loud, when it is at 1k its ok but when ig et to around 3k-4k its horrible and when i let off the gas and depress teh clutch it goes away then comes back at idle
Nisif
02-27-2008 06:06 PM
moesrex
05-23-2006 08:55 AM
150, 170, adjustment, adjustments, compresion, compression, d16y8, good, lash, numbers, results, test, valve
