compression test
compression test
whats up...i just did a compression test on my engine ...im using a 95 gsr motor with a drag 3 kit in a 95 hatch the motor has about 70k on it ..i also forgot to pump the gas while i was doing it. anyway the numbers where
cylinder#1...200
cylinder#2...180
cylinder#3...190
cylinder#4...195
anyway are these numbers fine or are they bad...the engine was at normal operating temp... i pulled the ecu plug but i FORGOT to push the gas pedal to full throttle would that effect the numbers...thanks alot let me know
cylinder#1...200
cylinder#2...180
cylinder#3...190
cylinder#4...195
Re: compression test (lsvtec4door)
Do it again and you will find out if it makes a difference, I tested my GSR but I pressed the gas down. Mt numbers are 220/210/215/215 but mine is a JDM so it will have a little more than a USDM.
