Honda S2000 Honda S2000
LOWERING QUESTION????
Old Jan 15, 2007 | 11:12 PM
ek_s2k's Avatar
Default LOWERING QUESTION????
HOPEFULLY YOU CAN HELP ON THIS ONE.... i changed my spring to a lowering spring and installed it but i noticed that the front is not balanced i mean one side is lower than the other,,what's wrong with it?is it the shocks maybe or something else...hopin u can help with this one,,,thanks
Old Jan 16, 2007 | 07:54 AM
Rahjahdat's Avatar
Default Re: LOWERING QUESTION???? (ek_s2k)
Maybe you put one of the rear springs in the front? More detail would help.
Old Jan 16, 2007 | 09:03 AM
Francesco's Avatar
Default Re: LOWERING QUESTION???? (Rahjahdat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rahjahdat &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you put one of the rear springs in the front? More detail would help.</TD></TR></TABLE>
yeah look into it.
also, how long have they been on? they need to settle.
Old Jan 16, 2007 | 09:23 AM
s2kdre's Avatar
Default Re: LOWERING QUESTION???? (Francesco)
what springs are they?
Old Jan 16, 2007 | 09:27 AM
Mr. Projekt's Avatar
* B A N N E D *
This sounds like the case. What springs did you get?
Old Jan 16, 2007 | 11:23 AM
ek_s2k's Avatar
i had skunk2 lowering spring and stock shocks ,, i didnt switch the front and rear coz i lowered the front and after that the rear..thanks
Old Jan 16, 2007 | 11:31 AM
big pete's Avatar
Default Re: (ek_s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_s2k &raquo;</TD></TR><TR><TD CLASS="quote">i had skunk2 lowering spring and stock shocks ,, i didnt switch the front and rear coz i lowered the front and after that the rear..thanks</TD></TR></TABLE>
You probably put one of the rear springs on the front. The springs are fairly close in size (at least the eibach ones I have are)
Old Jan 16, 2007 | 11:54 AM
s2kdre's Avatar
Default Re: (big pete)
i used to have skunk2's did u put the ones with more coils in the rear?
Old Jan 17, 2007 | 01:15 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (s2kdre)
the thicker ones go in the rear. Just because you lowered the front first doesnt mean you couldnt have mixed them up. You could have installed a rear spring on a front shock. It HAS to be the springs since they're what dictate the height of the car under normal circumstances. The fatter springs go in the rear. Make sure you dont have one fat one and one skinny one in the front. that sounds like what happened.
Old Jan 22, 2007 | 02:37 PM
driftdas2000's Avatar
Default Re: (B serious)
maybe the upper mounts were indexed off so the other side sits a little higher
Old Jan 24, 2007 | 08:07 AM
B serious's Avatar
Default Re: (driftdas2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftdas2000 &raquo;</TD></TR><TR><TD CLASS="quote">maybe the upper mounts were indexed off so the other side sits a little higher</TD></TR></TABLE>
No, the spring has 2 pig tails on it. If it doesnt sit exactly right, the shock wont be oriented correctly, and it wont bolt into the top or bottom mounts properly. The spring HAS to sit correctly for everything to bolt in. He had to have switched them.
KING PIN
Suspension & Brakes
Apr 16, 2008 07:44 PM
Midori Green
Sep 8, 2007 06:49 PM
boomersz
Suspension & Brakes
10
Jan 23, 2007 08:40 PM
2 point 0
30
Apr 10, 2004 08:52 PM
LoooseGSR
Apr 16, 2003 12:55 PM
