code P1259...help?
Old 09-19-2003, 06:34 PM
oneslowcivic's Avatar
Default code P1259...help?
OK, so i just had the ignitor and fuel relay replaced today and when i got home the check engine light was on and on the printout the shop gave me, it said this:
check engine light on - P1259 VTEC system problem rear bank
rear bank? i have no idea whats going on, it was not throwing this code before i took it in, and this shop says they wont do anything about it...help?
Old 09-19-2003, 06:40 PM
Default Re: code P1259...help? (oneslowcivic)
ok, just tested inside the car, throwing code 22....engine might help as well...00 USDM GSR motor
Old 09-19-2003, 06:55 PM
Smith Wise's Avatar
Code 22 - V-Tec System Malfunction
Take it back to the shop.
check VTEC Solenoid, VTEC Pressure Switch, and all wires assoicated with both for a short.
any difference in driving? still engaging vtec?? might be the ecu
Old 09-19-2003, 08:04 PM
Default Re: code P1259...help? (Jswpstdoff)
um, just checked the oil, down to the second line....filled it up to half way between the two lines...still check engine light...think it is centralized to the pressure switch, code 22...still dont know what is up with the 'rear bank' thing...
Old 09-21-2003, 12:57 PM
damn, followed some of the wiring from the pressure switch and found that one of the wires had broken off...sux, fixed it, running good now! thanx for the input
Old 09-21-2003, 04:44 PM
TurboBumblBee's Avatar
Default Re: (oneslowcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowcivic &raquo;</TD></TR><TR><TD CLASS="quote"> and found that one of the wires had broken off..</TD></TR></TABLE>
sounds to me like the mechanic cut the wire..
Old 09-22-2003, 04:29 PM
yea, i know...freakin hack shop
GibsonNO!
02-27-2009 06:05 PM
36Chitownrunnin
06-17-2008 08:44 PM
racereaper7
08-14-2007 08:56 AM
typer_801
03-19-2002 07:08 AM
Quick Reply: code P1259...help?
