code P1259...help?
code P1259...help?
OK, so i just had the ignitor and fuel relay replaced today and when i got home the check engine light was on and on the printout the shop gave me, it said this:
check engine light on - P1259 VTEC system problem rear bank
rear bank? i have no idea whats going on, it was not throwing this code before i took it in, and this shop says they wont do anything about it...help?
Re: code P1259...help? (oneslowcivic)
Code 22 - V-Tec System Malfunction
Take it back to the shop.
check VTEC Solenoid, VTEC Pressure Switch, and all wires assoicated with both for a short.
any difference in driving? still engaging vtec?? might be the ecu
Re: code P1259...help? (Jswpstdoff)
um, just checked the oil, down to the second line....filled it up to half way between the two lines...still check engine light...think it is centralized to the pressure switch, code 22...still dont know what is up with the 'rear bank' thing...
damn, followed some of the wiring from the pressure switch and found that one of the wires had broken off...sux, fixed it, running good now! thanx for the input
Re: (oneslowcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowcivic »</TD></TR><TR><TD CLASS="quote"> and found that one of the wires had broken off..</TD></TR></TABLE>
sounds to me like the mechanic cut the wire..
36Chitownrunnin
06-17-2008 08:44 PM
rodimus
11-06-2005 07:39 PM
