tdc spark @ different time than tdc on crank (solved)
Old 06-19-2014, 09:37 AM
CivicSmith's Avatar
Icon2 tdc spark @ different time than tdc on crank (solved)
Hey guys,
97 civic lx Wont start. Narrowed it down to the spark being out of time with the crank & cam pullies. Changed the crank positioning sensor, no effect. Tried multiple different distributors, no change. Tired other Computer from an Ex model same year, no effect. What could cause the spark to be off time with the timing belt? No CELs. Yes, the CEL does work.
Old 06-19-2014, 09:41 AM
Former User's Avatar
Default Re: tdc spark @ different time than tdc on crank
Check the mechanical timing. The timing belt may have snapped or slipped.
Old 06-19-2014, 09:48 AM
CivicSmith's Avatar
The timing is perfect. Newer belt, no rips or breaks.
Old 06-19-2014, 09:50 AM
Then how do you know spark is out of time?
Have you checked whether the spark plug wires are installed in the wrong firing order?
Old 06-19-2014, 09:53 AM
CivicSmith's Avatar
Wires are according to the hood diagram. I used a timing light to see that the timing was about not coming around when the light flashed. I used the same light on my 2000 Civic and it works perfectly.
Old 06-19-2014, 09:55 AM
CivicSmith's Avatar
I even added a yellow paint dot to the timing mark to see it better
Details? I don't follow you.
Old 06-19-2014, 09:56 AM
PHANTOM MENACE
24TEN's Avatar
If you're checking the spark as in ignition timing with a timing gun, it shouldn't line up with the TDC mark, it should be lining up with the 3 ignition timing marks.
EDIT: Are you sure you clipped onto the #1 ignition wire?
Old 06-19-2014, 09:58 AM
CivicSmith's Avatar
brb
Old 06-19-2014, 10:00 AM
CivicSmith's Avatar
yes, clipped the #1 wire. it is far from all 4 marks by at least a few inches. I don't know how else to describe it. When #1 cylinder sparks, the timing light flashes and there is no dot showing on the crank pully
Old 06-19-2014, 10:01 AM
Does the engine run fine?
Did you check whether the crank pulley metal key broke or fell out?
Old 06-19-2014, 10:05 AM
CivicSmith's Avatar
The engine ran great before this issue. Yes, the crank key is there and unharmed.
Old 06-19-2014, 10:06 AM
I was asking you how the engine runs now.
Old 06-19-2014, 10:07 AM
CivicSmith's Avatar
It won't start
Old 06-19-2014, 10:09 AM
Atomic1's Avatar
Did you replace the coil and ignitor with the distributor housing? Ignitors and coils are known to go bad on these cars. But as others have mentioned above, you should not be getting spark at TDC, it should be off by the speced degrees.
Your timing belt almost surely skipped a tooth or two. Set the cam at TDC1 and then post pictures of the cam and the alignment of the pointer with the crank pulley marks.
Is there bright white spark at all 4 plugs?
Does the fuel pump prime?
Old 06-19-2014, 10:14 AM
PHANTOM MENACE
24TEN's Avatar
^I have the same feeling.
Old 06-19-2014, 10:41 AM
CivicSmith's Avatar
How do I post pics? I changed the distributor to a new one, and one from a 97 ex that was running. Yes, all plugs spark bright. Yes, the pump primes to 40psi and holds there.
Old 06-19-2014, 10:43 AM
Go into Advanced edit mode and click the Manage Attachments button.
Old 06-19-2014, 10:52 AM
CivicSmith's Avatar
I am trying to upload pics... It keeps failing to upload.
Old 06-19-2014, 10:59 AM
CivicSmith's Avatar
https://fbcdn-sphotos-f-a.akamaihd.n...05102541_n.jpg
https://scontent-b-ord.xx.fbcdn.net/...14359284_n.jpg
https://scontent-b-ord.xx.fbcdn.net/...33746456_n.jpg
Last edited by Former User; 06-19-2014 at 11:26 AM. Reason: Trying to make pics display
Old 06-19-2014, 11:01 AM
CivicSmith's Avatar
Best I could do, sorry for the quality. Thank you for your help so far guys
Old 06-19-2014, 11:09 AM
It's clear from the pictures that the cam timing is correct.
But which of the 4 crank marks did you color yellow?
Old 06-19-2014, 11:11 AM
CivicSmith's Avatar
The single one that stands apart from the 3
Old 06-19-2014, 11:16 AM
The pointer works like the sight on a gun. I can only see the lower element of the pointer in your picture, though I think the timing must be at least very close.
Quick Reply: tdc spark @ different time than tdc on crank (solved)
