code 41..replace the o2 sensor??
Old May 15, 2006 | 08:51 PM
claytonsmith's Avatar
Default code 41..replace the o2 sensor??
im throwing a code 41 which is "Primary oxygen sensor heater "
what the hell is an oxygen sensor HEATER? will just replacing the sensor fix this or is there some "heater" of the sensor that i dont know about???
thanks to all!!
-Clayton
Old May 15, 2006 | 09:42 PM
Xscort's Avatar
Default Re: code 41..replace the o2 sensor?? (claytonsmith)
bump..i need to know to!
Old May 16, 2006 | 05:30 AM
EE_Chris's Avatar
Yes, there is heater element inside the O2 sensor. You can replace it (the whole O2) and hope that's the problem. Or you could get a meter and measure the heater resistance to see if it really is bad and then go from there.
Spec is 15-40 ohms.
Old May 16, 2006 | 06:14 AM
eXcelonTypeR's Avatar
Default Re: code 41..replace the o2 sensor?? (EE_Chris)
Get a HELMS service manual too so you follow the troubleshooting steps for solving a code 41
Old May 16, 2006 | 07:23 AM
pdiggitydogg's Avatar
http://www.sparkplugs.com for all your o2 sensor needs
Old May 16, 2006 | 09:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Yes, there is heater element inside the O2 sensor. You can replace it (the whole O2) and hope that's the problem. Or you could get a meter and measure the heater resistance to see if it really is bad and then go from there.
Spec is 15-40 ohms.</TD></TR></TABLE>
You forgot to mention the measurement should be taken between the 2 black wires.
Old May 16, 2006 | 09:09 AM
Chiovnidca's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sparkplugs.com for all your o2 sensor needs</TD></TR></TABLE>
Not all of mine, they dont carry bosch.
Old May 16, 2006 | 09:14 AM
EE_Chris's Avatar
Default Re: code 41..replace the o2 sensor?? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">You forgot to mention the measurement should be taken between the 2 black wires. </TD></TR></TABLE>
So instead of just picking up my slack, you point it out?
You forgot to mention that the O2 sensor needs to be disconnected from the main engine harness when making this measurement.
Old May 16, 2006 | 09:56 AM
Default Re: (Chiovnidca)
Not all of mine, they dont carry bosch. </TD></TR></TABLE>
why would you ever buy bosch???
every single one Ive ever owned (more than 3) lasted less than a yr...sometimes less than 6months
Old May 16, 2006 | 10:28 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">why would you ever buy bosch???
every single one Ive ever owned (more than 3) lasted less than a yr...sometimes less than 6months</TD></TR></TABLE>
Bacause that's what my wideband uses. They're cheap.
Old May 16, 2006 | 12:01 PM
wideband huh
fair excuse
924drb20
Dec 14, 2010 10:36 AM
slow96lude
Oct 15, 2009 05:07 PM
Bossup!
Sep 9, 2009 07:35 PM
draxxus07
Oct 13, 2005 05:41 PM
apok
May 16, 2005 09:52 PM
