Code 22, Help please?
Old Sep 6, 2006 | 08:11 PM
Metal Head's Avatar
Default Code 22, Help please?
I have a problem with my car, Driving on the highway, the CEL light came on, I turned the car off then on and the light went off and stayed off. I was concerned about it and checked to see if I got any codes. Got code # 22 two long blinks and 2 short blinks. Now I was told the code os for the Vtec sensor, So I swapped out sensors, reset the ECU, and I still get code 22, WTF???
Old Sep 6, 2006 | 09:35 PM
cwd14's Avatar
Default Re: Code 22, Help please? (slayerknot)
code 22 is ur vtec pressure sensor as you said, but maybe it is a wiring issue like the ground is no good or the wire to the ECU got damaged somewhere.
I would try running a new wire to the ECU and a new ground and see what that does.
Old Sep 8, 2006 | 09:04 PM
Metal Head's Avatar
Default Re: Code 22, Help please? (cwd14)
ok, the vtec pressure sensor is the bottom one with a green clip with 2 wires, or the top one with 1 wire?
I traced all the wires they look fine, mabey ill cut the ground and re-ground it to a better spot..
Thing that is weird, I DON'T get CEL, but when I check for codes, it throws 22.
Old Sep 8, 2006 | 09:10 PM
axtran's Avatar
reset ecu again.
Old Sep 8, 2006 | 11:08 PM
cwd14's Avatar
vtec pressure sensor has 2 wires, it is the one with the green plug. here is a link to a picture http://www.distincomputers.com...2.JPG please excuse my crap *** wiring in that picture lol.
Old Sep 12, 2006 | 06:55 PM
Metal Head's Avatar
ok, so I spliced in another wire into the black wire on the pressure sensor, and grounded it directly to the battery, reset ecu 2 times, I still DON'T get CEL, but when check for codes I get 22.
Old Sep 12, 2006 | 07:28 PM
Metal Head's Avatar
Default Re: Code 22, Help please? (boostless95ex)
Even though I don't get CEL, but the code is still there, Will Vtec work? How do I tell if Vtec works?
Old Sep 15, 2006 | 02:35 PM
cwd14's Avatar
get on the freeway and slam the gas pedal to the floor till you get to whatever rpm u vtec is supposed to engage and you should hear the engine's tone change. mine engages at like high 5000's. or at least that is when I hear the difference.
Jdmkids Manny
17
May 12, 2016 02:18 PM
92 CiviC H.B
Apr 20, 2010 02:36 PM
Metal Head
Sep 28, 2006 11:39 PM
Ls1 FD3s
May 18, 2004 12:19 PM
RoaringTurtle
18
Aug 5, 2002 01:17 PM
