CODE 19 Automatic transmission lockup control valve
I have a check engine light and it is throwing code 19 (Automatic transmission lockup control valve). I have a manual transmission. Any idea if what could be the problem? Maybe another noob question.
Thanks
Thanks
Re: CODE 19 Automatic transmission lockup control valve (Soichiro-son)
Did you do a auto to manual swap or are running a auto ECU? If neither, reset the ECU and see if it comes back.
Re: CODE 19 Automatic transmission lockup control valve (nsxmatt)
hi i have a auto to manual conversion the problem is code 19 which is the automatic transmission control valve . i already change my ecu to manual ecu. then reset. it still appears in my cel. what are others possible links couses that problem? is there some one could help me? i have a d16a engine only.... and i dont know what is the problem with auto matic trany lockup control valve...
hi shoichiro my name is don i have same problem with your b4... but still my cel is on light. what else couses those check engine lights?
hi matt do you have any idea of automatic transmission lockup conrtol valve is? coz i do the swap yo auto to manual....
gsxr1k05
10-25-2006 08:21 AM
crnimacak
12-31-2005 04:30 PM
your username here
11-29-2003 04:58 PM
virginia_dude
11-14-2003 06:44 PM
