Clutch Whine - Help Needed
Old 03-27-2008, 08:41 AM
Josh00Si's Avatar
Default Clutch Whine - Help Needed
Lately I have noticed a high pitched whine coming from what I think could be the clutch.
When I crank the engine, there is a whine coming from under the hood. If I barely rest my foot on the clutch pedal (or fully depress the pedal, for that matter), the whine goes away. The sound is present whether I am in neutral and stationary or running down the highway at 80mph but it only happens when my foot is off the clutch. The whine goes away each time I shift.
Anyone have any idea what it could be. I have heard it might be the input shaft bearing or the throw out bearing.
2000 Si - 70000 Miles
Old 03-27-2008, 08:45 AM
blk92_d16's Avatar
TOB
Old 03-27-2008, 01:04 PM
crazi_E's Avatar
Default Re: (blk92_d16)
TOB = throw out bearing
Old 03-27-2008, 01:05 PM
95jeremie's Avatar
Default Re: (crazi_E)
x3
Old 03-27-2008, 01:45 PM
Kurly's Avatar
Default Re: Clutch Whine - Help Needed (Josh00Si)
like others b4 me said its the TOB.. mite as well buy a good clutch/flywheel/ lsd while the tranny is off tho.. good luck
Old 03-27-2008, 02:40 PM
csulliva's Avatar
Sounds like it's the input shaft (or main shaft) bearing. $20 part, lot of labor. But if you're patient and have a shop manual, you can tackle it yourself with a free weekend.
If it were the throw out bearing, it would make the sound when you pressed the pedal, not when your foot was off it.
if it's the ISB, it will quiet down when your foot is on the clutch.
Makes sense if you think about it. the TOB is only in use while you have the clutch depressed, so it would only make noise at that point. The ISB is only spinning when your clutch is engaged (i.e. you're not touching the pedal) so that woul be when it would make noise.
I don't know what those 3 are talking about. But I suspect, as is often here, one person got it mixed up then a few agree to bump their post count.
edit: BTW: there's a decent how-to for the ISB in the FAQ, might want to check that out.
Old 03-27-2008, 02:44 PM
1992Si's Avatar
Default Re: Clutch Whine - Help Needed (csulliva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by csulliva &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like it's the input shaft (or main shaft) bearing. $20 part, lot of labor. But if you're patient and have a shop manual, you can tackle it yourself with a free weekend.
edit: BTW: there's a decent how-to for the ISB in the FAQ, might want to check that out.</TD></TR></TABLE>
X2
hcs1jimmy
04-19-2011 04:12 PM
red_rex_89
10
05-06-2007 07:13 AM
maxogsr
06-22-2005 06:46 PM
katb16vo
04-24-2004 06:04 AM
4potnick
11-09-2003 12:32 AM
Quick Reply: Clutch Whine - Help Needed
