clutch engagement issue
ok heres the deal.
95 delsol with a cable tranny b16a.
hasport hydrolic to cable conversion.
the issue I am having is that the clutch will no longer engage.
the pedal has absolutly no pressure in it whatsoever and when you push it down it goes to the floor and stays there.
the car is in nutral now and I cannot get it into gear. the system has been filled and bleed. and still nothing. it is my buddies car he came up to visit me and now he cant go home..
any ideas.
any ideas.
Re: clutch engagement issue (crxconnection)
someone up above you in this forum is having the same problem and also has the hasport conversion. Might want to give them a call, possibly something with their kit.
A friend of mine had this problem. I believe you have to adjust the pushrod on the kit to where there is a lot of tension on it. It worked finally, just took some adjusting and tweaking...
Palmertime
07-12-2005 04:40 PM
