cluster question
cluster question
i got a ex cluster in my 96 hatch now. why doesn't the gas light go on when my gas needles goes past the E? also, the cluster has the symbol to let you know when the doors are open, why doesn't that go off when the doors are open?
Im asuming that your using a 96-00 ex cluster.
I've put a 2000 ex cluster into my 98 cx with no problems. The low gas light went on just fine. Everything is just plug and play and you shoudn't have any problems.
Re: (chowmien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Im guessing your doing a cluster swap right? Well did you hook up the light to tell you when the gas is empty? What car is it in? </TD></TR></TABLE>
its into a 96 cx hatchback. i have used a ex cluster, nothing light up. now im using a ctr
Re: cluster question (Sl0wEK)
My low fuel light doesn't come on untill the gauge is nearly below the bottom line. (I have an EX cluster as well) **** idiot lights, they only come on in EXTREME conditions. Like when you have less than a quart of oil in your car, the low oil light will come on. (that is not exact it is an example to show the uslessness of idiot lights) Don't worry about the lights coming on, just watch your gauges and check you oil every time you fill up your tank.
Re: cluster question (delsoldude)
yeah either your bulbs are burnt out or wiring is messed cuz thats not sapposed to be like that at all. without the gas light, youll never know how far you can push it
z6htch
14
02-07-2013 07:18 PM
