Clock is working, but not working.....
OK, so I noticed my clock didn't appear as if it was working. So I pressed the button on the far right, and it showed 1:00. But when I let go, the time went away. Also, every time the car gets shut off, it resets to 1:00. What would cause this to happen? I didn't touch anything in the car!
Re: (95hbMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hbMatt »</TD></TR><TR><TD CLASS="quote">Mine did the same thing..it ended up being a fuse..I believe the under hood one..</TD></TR></TABLE>
Do you remember which fuse under the hood? Because it isn't clearly labled which is for the clock/radio...
It's in a 92 Civic Si HB
Modified by Double_Dk at 4:53 PM 6/27/2003
Re: (Double_Dk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Double_Dk »</TD></TR><TR><TD CLASS="quote">Do you remember which fuse under the hood? Because it isn't clearly labled which is for the clock/radio...
It's in a 92 Civic Si HB</TD></TR></TABLE>
if you are standing in front the car its the bottom left one. 20 amp i believe. there should be a extra 20 and a 10 amp fuse there so you can just use the 20 one.
Re: Clock is working, but not working..... (Double_Dk)
Thanks for posting this. My clock has done the exact same thing ever since my car was stolen. They took the radio and I had a feeling it was related...
Mine did the same... check the fuses under your hood... It was either the ecu fuse... or the back-up fuse (7.5A -- RED)... check both!
Re: Clock is working, but not working..... (94HybridEX)
It's the backup fuse. Look on the lid and it will show you which one it is.
matchewspoo
05-02-2010 01:47 PM
themackingking
Audio / Security / Video
07-25-2004 07:24 AM
OR-G
05-22-2002 07:48 AM
