CKF Bypass Trick'
CKF Bypass Trick'
Would it still apply if u have a obd2 to obd1 conversion harness, because when im rolling off and if i dont apply enough gas at 1500 rpm the car starts to studder
Re: CKF Bypass Trick' (ennah)
What car/engine? The CKF Bypass is for emissions, mainly. It's for people running a JDM OBD2 or OBD1 engine in an OBD2 car and want to use an OBD2 USDM ECU to pass BAR in Cali or emissions in states where they plug in the scan tool. I'm in AZ and in Phoenix and Tucson they use the scan tool for OBD2 cars which are '96 and up, I believe. The point of bypassing that sensor is so that you don't have to replace your oil pump on your JDM engine to use a USDM ECU.
Midnight EG6
10-21-2012 10:39 PM
Brugalontherocks
04-28-2008 08:10 PM
tour de france turbo
09-21-2006 05:22 PM
