B20 EG Hatch ignition problem
Old 11-20-2009, 05:34 AM
Elgrys.Mendez's Avatar
Default B20 EG Hatch ignition problem
Hey H-T, i need your help. I have a 93 EG Hatch with a B20 swap Gsr Heads on it, problem is this. The car has a G5 alarm and when i go to turn it on sometimes it turns on, sometimes it doesnt even crank over, and when that happens i have to push start it. What can be the problem?
Old 11-20-2009, 05:36 AM
azandford's Avatar
Default Re: B20 EG Hatch ignition problem
does it have a killswitch?
Old 11-20-2009, 06:12 AM
No Kill switch...I dont know what's the problem, sometimes it starts over right on a dime, and sometimes it doesnt even crank over, do you think it might be because of the alarm?
Old 11-20-2009, 06:20 AM
azandford's Avatar
check your ignition wiring for a kinked or exposed wire. That might explain why it would only work sometimes. I would "play" with the wiring while its trying to start to see if it fires up then. If not, then do the basics such as checking the plugs wires and dizzy
ceeejay
02-02-2005 09:28 PM
zanthrax
Audio / Security / Video
11-24-2003 02:53 AM
KimChiKid
07-06-2003 07:30 AM
TORQUE MONSTER
06-25-2002 10:42 PM
Quick Reply: B20 EG Hatch ignition problem
