Civic SI Side Skirts question
I was wondering how differ is the 99-00 si side skirts from a 92-95 side skirts? would they be compatible? also does anyone has pics of the 99-00 si side skirts? just curious thanks
overrated.
Re: Civic SI Side Skirts question (milton)
'99-'00 Si sides are longer obviously, I've heard that you can make them work although you'd have to do some cutting to make them the correct length.
Correct me if i'm wrong, i've never tried it.
Location: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Re: Civic SI Side Skirts question (OnePointFive)
i had 96-00 sideskirts on my 93 coupe.fit good.
i am in the process of buying a set of hatchback ones for my hatch. i think they look hellla lot better than stock 92-95 IMO
Re: Civic SI Side Skirts question (NJHatch)
yeah thats what i was told. i just bought the car and one side didnt have a side skirt so i wanted to get ones. Someone told me that the 99-00 si fits the 92-95 coupes. A pic would be nice thanks
Re: Civic SI Side Skirts question (Chillin94hatch)
Look on the last page of the FAQ thread and learn to use the search button. This is covered damn near weekly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faq thread »</TD></TR><TR><TD CLASS="quote">
sup guys alot of people are askin how i did this so here you go hope this helps.
first you have to cut the front of the EK sides about 2inches. (sorry dont have any before or after pictures) just cut it the same length and the EG ones.
then put those white clips onto the EK sides and then see where it lines up with the chassis (mine already has the square holes there cuz i drilled it already) to get the square holes i just drilled a big hole with a drill, then got a square file and just filed it to the right size square.
I didnt do all of them got lazy but if you see two holes on the picture the one on the left is the one i drilled !!!(dont try to make a hole for the first one in the front cuz there is something behind it and i couldnt get my filer in there.)!!!
this picture show the white clips in the holes for the EK ones
it should fit in after all this and the front will flare out a little so push the sides in and just use a selftappin screw to hold it in. also on the bottom the very far rear clip should clip in. if you want all the clips in there you have to drill holes on the EK sides so it will line up with the holes already there and then use those clips that came off of the bottom (those black screw type things)
Your done!!!!
Copied and pasted from the faq thread.
Your done!!!!
Re: Civic SI Side Skirts question (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Copied and pasted from the faq thread. </TD></TR></TABLE>
That post tells you how to fit EK sides on a 92-95 Civic Hatch. I think these guys are talking about a 92-95 Coupe.
Re: Civic SI Side Skirts question (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja »</TD></TR><TR><TD CLASS="quote">
That post tells you how to fit EK sides on a 92-95 Civic Hatch. I think these guys are talking about a 92-95 Coupe.</TD></TR></TABLE>
I thought the coupe had the same sideskirts as the hatch.
I thought the coupe had the same sideskirts as the hatch. </TD></TR></TABLE>
the coupe sideskirt is about an inch longer than the hb sideskirts
Re: Civic SI Side Skirts question (lilredridinghood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredridinghood »</TD></TR><TR><TD CLASS="quote">
the coupe sideskirt is about an inch longer than the hb sideskirts </TD></TR></TABLE>
Damn, good to know. I learned something new today. With the 6th gens they're all the same length (all have the same wheelbase as well).
fbp sides on my car
i had to drill about 5 or 6 new holes then square them out after. the only one that fits without drilling a new hole was the hole closest to the rear well.
you should be fine...I have put 96-00 coupe side skirts on a EJ1 and no one can't tell it apart.
looks pretty good , just fitted right on perfectly...
Re: Civic SI Side Skirts question (stpcivicguy)
check my sig for the pics of my 00 si sides and i didnt think they would fit a EG, dunno maybe they will on a side note i think we need a fitment guide on here like will ITR seats fit in this chasis and rate 1 to 10 how hard the install was again just IMO
CR91X
03-29-2008 11:22 AM
JSJ EG6
10-18-2002 08:01 PM
