1993 civic coupe DX
1993 civic coupe DX
I have been having some problems lately , ok my lamp on the roof wont work , bulb is good.My backlight airconditioner panel usually does not work , some times it will go on , and then i tap it because its a very light faint light up n it turns off , and my rear defroster button does not light up. Now i had my car converted to pwoer , i duno if that has n e thing to do with it but its gettin annoying , n e ideas?
Re: 1993 civic coupe DX (1993CiViC DXwHiTe)
what's wrong with your SPELLING? i got the lamp part until you throw those words/letters in.
as for your lamp, try checking all fuses see if they are working. if not there might be a short connection somewhere along the line.
Re: 1993 civic coupe DX (handa)
Hmmmm , spelling seems to be okay , expcept for power which was a typo , not a spelling error. I actually did come on HT to get an english lesson , i happen to have a perfect grade in english.But n e way , I'll retype it for you. The Lamp (light on the roof of the car) will not turn on no matter what. The back(white-ish) light for the Air conditioner will turn on sometimes... and then ill tap it because only a small portion of it will turn on and then the whole back light display will go dark again, the buttons work when u press them and they light up green or whatever the color is when its pressed.The rear defroster button will not light up.Also today my right passenger side headlight(the white-ish light) went out while the other side was fine , i tapped it kind of hard and it turned on again. So yeah thats about it any solutions or ideas? Oh and feel free to correct and criticize any grammar mistakes.Thanks ,
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993CiViC DXwHiTe »</TD></TR><TR><TD CLASS="quote">Hmmmm , spelling seems to be okay , expcept for n e way , </TD></TR></TABLE>
Should be anyway.
As far as your problems go, it sounds like it's just a loose connection. My dash lights (for a/c) do the same thing and my headlight would do the same thing on occasion.
Should be anyway.
JDubya
03-13-2003 07:44 PM
