Civic idles low and dies Need Help!
ok i have i 99 civic with a gsr swap an in the mornings or wen its cold i start the car an it instantly dies an if i give it gas it sputters and turns off somtimes it just turns off.. i have to be turning it back on an giving it gas an any reason why it sputters wen i give it gas??
well after it warms up it goes back to normal! ive cleaned my iacv an still does the same thing any suggestions??? Thanks~
Re: Civic idles low and dies Need Help!
What have you tried to fix it?
Is it flooding?
Have you tried taking your plugs out to see if they are soaked in gas?
Is the timing correct?
Also have you tried cleaning your FITV?
Just some suggestions. Need more info
Is it flooding?
you may need to adjust you idle screw a bit....make you you follow procedure.
Engine fully warm up
disconect you AIC
turn car on (may need to hold gas for while to get it to idle)
Turn the idle screw out quarter turn out every 2 minutes
set you speed idle at 8500 rmp
plug AIC back on
disconect battery for 30 seconds
hope it helps>>>>
disconect you AIC
plug AIC back on
hope it helps>>>>
^^ If your not getting any spark and you know it's not your wries or plugs, then yeah chances are it's your dizzy.
If you don't want to buy a whole new dizzy, remove your ECM from your dizzy, and take it to the nearest auto parts store and have it tested. If that tests ok, check your rotor and cap to see if it needs replaced. If that's ok, try replacing your ignition coil.
Hope this helps
Hope this helps
Yesterday when i got home from work i swiched out the AICV and map sensor and while i was at it i got a new thermostat since it didnt have one (would take for ever to warm up) an this morning it turned off on me 3 times and then stayed on an drove it to work running fine dunno why its turning off???
actually my rotor looks like it needs to be replaced got a new one and the screw to it is like stuck on there couldnt take it off an gave up on it
If your rotor hasn't been removed in a while, the first time you take it off is difficult. Took me 15-20 one time. Just have patients
