civic ex with b16 swap high reving
Old 02-12-2011, 05:22 PM
bradabu's Avatar
Default civic ex with b16 swap high reving
i swapped in a b16 into my civic but the idle is high, 2000 rpm. why? i have no vacuum leaks on IM as i checked by spraying car cleaner...it has a constant idle at 2. when driving in gear, cruising i dont need to apply gas as it has enough to keep me moving.also new IM gasket and throttle body gasket looks good. any help
Old 02-12-2011, 05:25 PM
TaffetaEj6's Avatar
Default Re: civic ex with b16 swap high reving
try adjusting your idle screw, and you may need to clean your fitv.
Old 02-12-2011, 06:11 PM
92bseries's Avatar
try adjusting the tps as well if needed, if your cruising and u dont need to apply gas, it sounds like its stuck open a little bit. try checking throttle cable to for enough slack. jus lookin at everything for ya
rspecturbo
01-03-2015 08:52 AM
DuecedSol
Honda Civic (2006 - 2015)
10
08-08-2014 07:26 PM
bradabu
06-28-2011 04:03 PM
michael_antoi
02-22-2006 03:36 AM
Quick Reply: civic ex with b16 swap high reving
