civic dx will not start
ok, so the head gasket was replaced, the timing is right, I have fuel, I have spark, the distributor is perfectly fine, plugs and wires are all good, the car cranks but won't start. I checked all the grounds and they are fine. I am stumped, this thing should start and run.
Suggestions? Thoughts?
94 civic d15b7
94 civic d15b7
Re: civic dx will not start
how did u check fuel? r ur fuel lines hooked up right? that was my problem on a mazda i owned. fuel in the lines, spark compression but the lines where switched.
Start by double checking the mechanical timing.
Are the plug wires in the wrong firing order on the distributor cap?
Have you measured the cylinder compressions?
the timing was a tooth off and then readjusted, the plug wires are in the correct firing order, I was planning to check compression tomorrow. thanks for the suggestions, any other ideas? maybe something simple I am overlooking?
playa24vtec
19
11-05-2013 09:19 AM
ryan_1014
10
09-11-2010 10:02 AM
Herbie
04-21-2010 09:57 AM
drift2004
07-20-2009 07:46 PM
