civic b20 swap gsr transmission issue!
Old 06-24-2014, 05:31 PM
ekhatch1227's Avatar
Default civic b20 swap gsr transmission issue!
Specs:
1996 civic
B20b engine
Gsr transmission
Sachs clutch kit I believe
Daily driven but today I went to back out of a parking spot and heard a slight pop noise in reverse.
Put it in nuetral to switch to first gear and it wont go into any gear.
I have a clutch pedal and the slave cylinder is working.
if I shut it off it will go into any gear fine.
If I put it in first and start it up I hear a bad grinding noise but it will still move when releasing the clutch.
If it is in first making the noise and I drop it into the neutral the noise will immediately go away.
Any thoughts
Throwout bearing came apart?
Clutch spring?
Im.going to tear it apart but getting some ideas.
Old 06-24-2014, 05:34 PM
The Grumpiest
grumblemarc's Avatar
Default Re: civic b20 swap gsr transmission issue!
Check the master. Fluids topped off?
Old 06-24-2014, 05:54 PM
Yes fluids were perfect. Had a friend watch the slave cylinder it did move when I depressed the clutch pedal and it was new about 2000 miles ago. Clutch pedal feels the same with the car running and not running. No grinding when in neutral only when shut it off and start it up in any gear.
Before this started it shifted perfect did not grind or hard to get into gear
Old 06-24-2014, 06:37 PM
Fliptard's Avatar
trans fluid full?
Old 06-24-2014, 07:42 PM
Yeah it was filled and no visible signs of external leaks.
Doing more research it seems maybe one of my clutch springs may have broken causing the grinding noise
Old 06-24-2014, 08:35 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
That sachs clutch was probably a bad choice. Could be some broken clutch fingers or a busted clutch fork.
Old 06-25-2014, 03:19 AM
Fish Twig
tony_2018's Avatar
Clutch spring popped out.
Old 06-25-2014, 05:43 AM
That was my guess im pulling it alart tonight when I get off work ill post up some pics.
That clutch was in it when I got it.
Just ordered an exedy stage 1 last night.
Old 10-08-2014, 07:26 AM
RAB3's Avatar
Having the same issue, what was the problem?
95hbMatt
Transmission & Drivetrain
10
07-28-2011 01:17 PM
Tim2179
03-25-2008 08:39 PM
E Swift
12-01-2004 02:57 PM
PH3593A
11-02-2004 03:10 PM
Quick Reply: civic b20 swap gsr transmission issue!
