check engine code 5 ... map sensor
Old Apr 20, 2005 | 04:15 PM
teefunk01's Avatar
Default check engine code 5 ... map sensor
92 Civic dx > 93 d16z6 swap
car is throwing a check engine light with code 5.. (map sensor)... Im not sure as to what to do...the car idles rough and sometimes wont start...any help is appreciated..
Old Apr 20, 2005 | 04:29 PM
ian.'s Avatar
Default Re: check engine code 5 ... map sensor (tphan4)
its probably no good so replace it that's what i did and worked out fine
Old Apr 20, 2005 | 04:32 PM
unknown0001's Avatar
Default Re: check engine code 5 ... map sensor (IC33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IC33 &raquo;</TD></TR><TR><TD CLASS="quote">its probably no good so replace it that's what i did and worked out fine</TD></TR></TABLE>
Correct
I have/had the same problem but never replaced mine and it works good now
chucky86
Oct 13, 2011 02:46 PM
samurai_x6
41
Sep 23, 2007 12:32 PM
philosofy1
10
Aug 26, 2006 07:35 AM
