cheap horsepower tips or tricks?
Old 08-16-2002, 08:28 PM
bluedelsol's Avatar
Default cheap horsepower tips or tricks?
I need some cheap horsepower tricks or tips for my little honda del sol (only 1.5L, 205BHP). just need to speed it up a little for a local track. any tips can help, planing on porting intake manafold and exhaust ports, just want to know if there is any other hidden horsepower tricks?
Old 08-16-2002, 08:30 PM
GDD Member
slomofo's Avatar
Default Re: cheap horsepower tips or tricks? (bluedelsol)
Take your hood, fenders, bumpers, doors, air box, exhaust, and interior off/out for lighter weight and to let it breathe better, and don't forget to advance your ignition timing. jk
Old 08-16-2002, 08:35 PM
bluedelsol's Avatar
Default Re: cheap horsepower tips or tricks? (slomofo)
i'm going to advance my timing in the next few days, but i;d rather not take off half my boddy, i have to drive it to work every day.
Old 08-16-2002, 08:39 PM
owen_the_soyboy's Avatar
ultralight crank pulley....
from 8 lbs to 6 ounces will help you feel a power increase but it may not prevent your motor from shaking itself apart in 50k miles.....
cheap though at $170 or so.
Old 08-16-2002, 08:42 PM
bluedelsol's Avatar
How mutch horsepower do you think i could get if i hollow my cat or replace it with a strait pipe
Old 08-16-2002, 09:15 PM
deepnite's Avatar
205 hp ?..if i had only been that lucky dude..ur already at ur NA limit..NOS is cheaper than any FI set up
Old 08-16-2002, 10:56 PM
jus f0 dekarayshunZ
ciRcuitJerk's Avatar
Default Re: cheap horsepower tips or tricks? (deepnite)
take out a/c do the timing it helps a bit....i think the hollowing out part will help a bit also my friend did it on his hb and you can tell a bit of difference also it makes it a little louder...louder=faster haha jk
Old 08-16-2002, 11:01 PM
D Tranny Guru
Mista Bone's Avatar
Default Re: cheap horsepower tips or tricks? (owen_the_soyboy)
D15 already has the LW pulley.
D Tranny Guru
Mista Bone's Avatar
205 BHP? I think you mean 102 hp.
Old 08-17-2002, 12:17 AM
.nate's Avatar
Default Re: cheap horsepower tips or tricks? (Mista Bone)
say it with me: junkyard turbo setup.
Old 08-17-2002, 12:29 AM
bullz's Avatar
Default Re: cheap horsepower tips or tricks? (N8)
Just drive w/ your chassis and a helmet.
Old 08-17-2002, 12:36 AM
Ek-CoolGuy's Avatar
Default Re: cheap horsepower tips or tricks? (iLLestjr)
let me be the first to say...
NAAAAAAAAAWWWWWWWWWSSSSS
Old 08-17-2002, 01:40 AM
civicgsr94's Avatar
If anything you may loose horsepower due to lack of backpressure. Too much backpressure is bad but very little is bad also(unless forced inducted) My friend put a strait pipe on his prelude and the car was sluggish. I don't have any dyno results to back it up though.
Old 08-17-2002, 04:54 AM
EKB18BPR3's Avatar
do u have any bolt-ons? maybe work on suspension/brakes? some guy on here always quotes "doesnt matter how much hp u got, if u cant make the next corner than ur dead" or something like that...well u get the picture
Old 08-17-2002, 06:10 AM
deepnite's Avatar
Default Re: cheap horsepower tips or tricks? (dniedacess)
lightweitht wheals if u havent already done that
Old 08-17-2002, 10:57 AM
bluedelsol's Avatar
i'm looking for strait line speed not cornering, it's for a local drag strip here in VA.
Old 08-17-2002, 11:11 AM
Al Bundy's Avatar
How'd you get 205 bhp from a 1.5 liter? I have a 1.8 and only have 170 bhp.
Anyways heres a couple of tips: advanced timing, weight reduction, coolant bypass from the throttle body, remove p/s and a/c belts
[Modified by OBD1KNOBE, 8:26 PM 8/17/2002]
Old 08-17-2002, 11:30 AM
neveronlines2k's Avatar
Default Re: cheap horsepower tips or tricks? (OBD1KNOBE)
Pull ac and power steering . Take out factory sound dampining meterial from trunk. If you have cruise control pull that.
When you'r at the track pull you'r front and rear bumper supports. (dont recomend that for street driving because if you crash it could be very bad!!!). Also remove consouls any seats not in use etc. Other than that NOS is the least expensive power adder available , just remmember motors aren't cheap so nos nicely .
DaWingler
13
09-10-2013 04:35 AM
Ragecloak
46
08-11-2006 10:37 AM
crazychrisegt
08-26-2004 01:39 PM
bluedelsol
08-17-2002 10:59 AM
CRXBoy
64
04-02-2002 05:43 PM
Quick Reply: cheap horsepower tips or tricks?
