changing timing belt w/out messing up valve timing?
how do i correctly change my timing belt w/ out messing up my valve timing? i searched for help, didnt find much. enlighten me.
Re: changing timing belt w/out messing up valve timing? (EGhatch33)
Pick up a helms manual from your local autoparts store..Or download the free manual from hondahookup.com..
If its correctly timed now, make sure the crank and the cam shows TDC. Take off the belt and put the new one on in the order its supposed to go. Sounds tricky, but if you pick up a helms and take ur time you will be fine.
