CHanging CV on 94 with auto?
I noticed my left side(driver) CV boot is ripped so I know I gotta replace it. My question is..How do I get the nut off the axel? I dont have a air gun. Could I do it with a big breaker bar with the car on the ground? Is the next step to remove the brake rotor....then ball joint then use a puller to push the cv out of the hub...then remove the cv?....last question is how do I tighten the axel nut once it on?
Re: CHanging CV on 94 with auto? (AnitRiceSuperStar)
ive never tried it without an air gun. It can probably be done but it wont be easy. Yep you gotta take off the axel to change the boot. fun job :D
Search is your friend.
No air tools needed, 32mm socket I believe and a breaker bar will do it. I just did the drive with the breaker bar attached to the car thing and it loosened no prob.
Good Luck
Good Luck
MikeTV
12-25-2004 11:05 AM
gsrcivic619
10
01-05-2004 04:07 PM
