Changing Auto Shift Points
Hey, Basically I wanted to know if there is a way I can move my Automatic Transmission's shift points around in the RPM range, so I can get it to hold 1st longer?
Thanks.
Thanks.
Re: Changing Auto Shift Points (chowmien)
check into uberdata. me and my buddies are starting to research that. it might have something in there to change the shift points.
http://www.ecimulti.org/uberdata/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">An easy way to hold first longer or any gear at that would be to get a manual transmission
haha
haha
Re: (eL)
It seems like these days every question I have I need to include rules for the thread so I don't useless posts. Like three of the above.
Does anyone actually know? Smart-asses, references to Manual Trannys and suggestions involving b-series engines are not appreciated.
Re: (Paprika)
I have tried to research this from time to time with no real luck. I first thought about this because on my previous bmw, there was a seperate ecu for the tranny you could modify with an aftermarket ecu chip to change shift points and such, come to find that honda's don't have that and all of it is in the main ecu. Now this is what I was told so if I'm wrong then someone please correct me cuz I would love to be able to modify the shift points on an auto tranny.
The only thing that you can really do to get an sort of performance out of the auto tranny is to go with products from companies such as http://www.LevelTen.com and TCI. Level Ten offers tranny modifications such as beefier components and upgraded torque convertors as with TCI. Wish you the best of luck with this and if you find anything out then please share.
Re: (Paprika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika »</TD></TR><TR><TD CLASS="quote">It seems like these days every question I have I need to include rules for the thread so I don't useless posts. Like three of the above.
Does anyone actually know? Smart-asses, references to Manual Trannys and suggestions involving b-series engines are not appreciated. </TD></TR></TABLE>
Who said anything about a B series engine?
Seriously though... you can't deny how much more sense it would make to have the manual transmission for whatever it is you're planning on doing in your automatic.
you can make your automatic shift very hard if you take out the accumulator and replce it with a stiffer spring or a bolt....the accumulator is what cushions your shifts...i know that you can change your shift points but its just hittin me right now...ill get back to you when i can remember.
Re: (Knightmare69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightmare69 »</TD></TR><TR><TD CLASS="quote">I first thought about this because on my previous bmw, there was a seperate ecu for the tranny you could modify with an aftermarket ecu chip to change shift points and such, come to find that honda's don't have that and all of it is in the main ecu.</TD></TR></TABLE>
Hondas have tranny computers too so uberdata wouldnt do anything.
Re: (Spoolin93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolin93si »</TD></TR><TR><TD CLASS="quote">Hondas have tranny computers too so uberdata wouldnt do anything. </TD></TR></TABLE>
some hondas so, but 92-00 civics have the auto tranny controlled by the ecu. there's no separate computer for the auto tranny.
why not just shift manually when you need to?
If your gears go P R N D D3 2, take the console apart, right underneaht (wher ethe 2 is and the stick stops) theres a blokc, remove that block or shave it down so if u hold down into that conrer the car stays in first untill you hit redline. IF u hit redline too soon then ull need to change it.
Re: (rentacar4dr)
Ok, much thanks to all of you that have responded, I appreciate it.
Seriously though... you can't deny how much more sense it would make to have the manual transmission for whatever it is you're planning on doing in your automatic.</TD></TR></TABLE>Right, very true. I am just asking for the time being. In hopes I could slip out a EEPROM or Flashrom, reprogram it and put it back in to gain custom shiftpoints.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93blkej1 »</TD></TR><TR><TD CLASS="quote">u could always drop it first and then shift into second when ever u want</TD></TR></TABLE> Thats what I have been doing but the transmission loves to fight w/me resulting in an inaccurate shift.
Modified by Paprika at 7:52 AM 2/13/2005
96blackaccordv6
07-10-2007 07:21 PM
RnEpmc
09-19-2004 03:59 PM
