CEL:#8..:P TDC.. why??
okay guys and gurls.. i have a 94 coupe dx with a z6 swap.. i have an adjustable cam gear and chipped ecu.. the cam gear is set at -4 and the xs is upgraded fuel and timing maps.. it drove well for about 3k.. it just now started to throw the check engine light for top dead center.. why? someone help.. thanks!
Re: CEL:#8..:P TDC.. why?? (eli_vang)
it is your distrubiator ?! (spell check ! ) you know !! the one on the other side of camgear .. with all the sparkplugs wired 2 it.. need a new.. dont think the TDC sencor can be changed... :-/
PS. why the - 4 one stock cam ?
[Modified by Zeus Zore, 5:29 AM 3/9/2003]
Just went throught the same dame thing with my D16Y6. TDC sensor went bad,car started idleing like ****, had to get a new distributor. There is pretty much no way around getting a new one, if you look at the sensor it would be easy to replace the bad thing is that you can' t just buy the sensor by itself.
Re: CEL:#8..:P TDC.. why?? (Zeus Zore)
okay coo.. thats what i was just thinking. i got a new dizzy coming to me already.. thanks guys! and i'm at -4 on the stock cam because at stock cam timing its hella sluggish.. 1/4 times went down as i lowered the cam timing.. thanks again
Re: CEL:#8..:P TDC.. why?? (13HYBRID20)
i didn't dyno it.. when i had my stock ecu in the car i was at +2.. it felt good with the stock ecu.. i chipped it with the xs chip and it was instant bog... so i took it to the track.. ran shitty times.. mid 15's with it at stock timing.. took it to a -1.. and down.. as i went down the times went down.. -5 was to much.. lost power, but still faster than anythig above it.. so -4 was it for me.. felt good.. felt like it lost a lil bit of low end but i could feel vtec.. i mean. grabbed a 14.8.. so it's all good with me.. and umm.. it didn't slip on the belt.. the gear didn't slip either.. thanks guys..
Dgrep
01-01-2018 01:16 PM
