Cause of Backfire?
Cause of Backfire?
Basically this means the engine is running a tad rich. I don't see black smoke so it's not overly rich but I don't want to be doing rice sparks all over the place. Plus it burns more fuel than I want it to. Will getting a FPR solve this? If it does, I'll pick one up this weekend.
I'll check timing as for ecu, it's the one that came with my 95 JDM motor. I don't know what the code that is though. I know nothing about the ecu since I let the shop do everything.
Re: Cause of Backfire? (breakaway)
they r new and so r the plugs...i won't throw this many codes if it was spark plugs...leak in the fuel tank ...too rich or too lean...knock...and i think vtec ...and cyclinder misfire in number # 4 (only if it revved close to 8K
Re: Cause of Backfire? (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">check your timing too, and possably use a lower octain gas, depending on what engine you have.</TD></TR></TABLE>
good idea
good idea
brokenojoke
05-29-2005 07:55 AM
