CAR WON'T START RUNNING OUT OF IDEARS???
dude my damn 99 ek won't start and i checked for spark there is no spark the distributor is re manufactured the coil is brand new. The car will start and drive but unexpectedly cuts off while driving kind of like it is running out of gas then wont start again. car is getting fuel though i took off the line from the fuel filter and kicked the car over fuel shot out so its getting fuel..........I can't figure it out I am running out of ideas man this **** is driving me crazy I went out to replace the ignitor tonight i replaced it and tried to start it, nothing! IM GOING NUTS PLEASE HELP!!!! CEL but no reader??? what could set off CEL that make no spark and these symptoms?
i love these threads cuz diagnosing is the best
ok check list:
check all grounds
u say it will start sometimes and that sometimes it will die on the road...u also said ur dizzy is a reman so check ur distributor... if not check coil for resistance...and how does it run when it does turn on?
ok check list:
check all grounds
Re: CAR WON'T START RUNNING OUT OF IDEARS??? (dan89crxsi)
I would check the CEL first. Jump the wire near the ecu and count the flashes. Search to find the instructions and code info.
Re: CAR WON'T START RUNNING OUT OF IDEARS??? (powerflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow »</TD></TR><TR><TD CLASS="quote">I would check the CEL first. Jump the wire near the ecu and count the flashes. Search to find the instructions and code info.</TD></TR></TABLE>
wow...+1 for the noob...always check your codes...thats whats the check engine light is for
Re: CAR WON'T START RUNNING OUT OF IDEARS??? (turbociviccoupe)
i did check the cel recently when the problem first occurred it was insufficient catalytic converter flow but i replaced the cat and the broke *** o2 sensor that was in the cat.........i then replaced the coil reset the cel and thought the problem was fixed then the cel came back on and the car cut off again and wouldn't start after like a week of driving.
Now.....When the car does run it runs shitty like it bogs at 3000+rpm and in high rpm near red line it is like it is missing and car jerks and bogs
????? WTF ????????
????? WTF ????????
alright i am going to get my boys code reader tomorrow i guess i can't do **** till then im up drinking and its pissing me off i got the dizzy here in front of me i am going to put the old ignitor back in and check the cel tomorrow please check up with me tomorrow i told ya this is driving me crazy i hate diagnosing!
how do i check the code without a code reader what wire do i jump? use a test light?
* B A N N E D *
it could be a fuel problem if ur not gettin anything from the check engine light
i don't think a light even comes on if your pump is fried
Re: (raphael)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael »</TD></TR><TR><TD CLASS="quote"> i love these threads cuz diagnosing is the best
ok check list:
check all grounds
u say it will start sometimes and that sometimes it will die on the road...u also said ur dizzy is a reman so check ur distributor... if not check coil for resistance...and how does it run when it does turn on?</TD></TR></TABLE>
Cowboy bebop rocks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">
wow...+1 for the noob...always check your codes...thats whats the check engine light is for</TD></TR></TABLE>
I'm a noob to, so +2. I had no idea you could check OBD-IIb cars by jumping a service connector - I didn't even know that OBD-IIb cars had a service connector there, all the ones I've seen have a service port under the dash for a scanner, nothing "jumpable."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 »</TD></TR><TR><TD CLASS="quote">it could be a fuel problem if ur not gettin anything from the check engine light
i don't think a light even comes on if your pump is fried</TD></TR></TABLE>
I doubt it's a fuel problem. He's NOT getting a spark and then it just DIES. It sounds COMPLETELY spark related. Usually stuttering and sputtering is involved with a fuel problem when it stalls.
At OP:
I'd replace the ENTIRE distributor and see where you are from there.
ok check list:
check all grounds
Cowboy bebop rocks.
At OP:
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
on the obd2 cars there is something jumpable...its a plug just like the obd1 cars...located on the passenger kick panel near the ecu...a code reader isnt necessary
Re: (turbociviccoupe)
ok..so if a OBD2 has a jumper to check the CEL like ^^^ said..you can prob use this https://honda-tech.com/zerothread/1171263 ...if not, just take it to autozone and have them check it out for free...then check back with the code you're gettin...
on the obd2 cars there is something jumpable...its a plug just like the obd1 cars...located on the passenger kick panel near the ecu...a code reader isnt necessary </TD></TR></TABLE>
Oh, I see, I was just remarking that I've never seen it. Oh well, live and learn.
EDIT:
Well, had no idea that you could do the same thing to OBD-II cars.
Modified by Syndacate at 5:33 AM 1/25/2007
EDIT:
There is all sorts of info/step by step how to's in the archives about this. Remember that there could me many codes not just one. In some situations I've seen one smaller problem throw multiple codes.
Re: (B18CivicEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg »</TD></TR><TR><TD CLASS="quote">...if not, just take it to autozone and have them check it out for free...then check back with the code you're gettin...</TD></TR></TABLE>
how would i get it to autozone if it does'nt start?
Re: (dan89crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan89crxsi »</TD></TR><TR><TD CLASS="quote">
how would i get it to autozone if it does'nt start?</TD></TR></TABLE>
jedi mind tricks!!!
use the link 18civiceg gave...it explains how to check for codes. gl man
jedi mind tricks!!!
Re: (Syndacate)
Cowboy bebop rocks.
At OP:
I'd replace the ENTIRE distributor and see where you are from there.</TD></TR></TABLE> cowboy bebop is the shitznet. WTF tho mang check ur codes first
Cowboy bebop rocks.
At OP:
Re: (dan89crxsi)
Is this the right ignitor i dont think it is? doesnt screw into distributor and bracket from the old one doesnt fit on it
the old one
the new one
the old one
the new one
Happy Gilmore
05-13-2009 05:21 PM
