Car Won't Start Issue
Old 02-03-2009, 09:49 AM
Maness's Avatar
Default Car Won't Start Issue
All right, so has enough juice to turn on lights and stereo.
Tried jumping it yesterday with some crappy cables to no avail. Will be trying with some better/thicker cables this afternoon.
When you turn the key all that happens is all the electrical turns on and you can hear the fuel pump priming.
Assuming the alternator, not the starter? Possible relays? Any ideas?
Old 02-03-2009, 09:53 AM
SOHC_4dr's Avatar
Default Re: Car Won't Start Issue
more info needed!!! what car and engine? does it turn over or try to? have you done any recent mods?
Old 02-03-2009, 11:27 AM
Maness's Avatar
Wow I'm an idiot.
1998 Civic DX.
No recent mods besides the stock immobilizer nonsense being taken out because we were having these sort of issues.
Won't turn over, all that happens is electrical powers up, fuel pump sounds like its priming, but it doesn't pass this step. Have tried jumping twice to no avail.
Has a brand new battery, and we believe the alternator to work after me driving it home last week after getting a jump and it having full charge plus everything was receiving power where it should be.
Old 02-03-2009, 11:31 AM
xsaxisx's Avatar
could be your starter or corrosion on the wires.....
Old 02-03-2009, 11:49 AM
SOHC_4dr's Avatar
immobilizer issues are bitches as well. but yeah i agree to fisrt check the wires for corrosion and make sure your grounds are tight
Old 02-03-2009, 12:07 PM
Maness's Avatar
It's not even clicking when trying to start it... I guess I'll go back over and double check the battery cables...
When I brought it in last time they cleaned them up and made sure they were firm as well as removing that damn immobilizer.
Annoying.
Old 02-03-2009, 12:09 PM
SOHC_4dr's Avatar
hmmm. with that immobilizer it makes it tough to know what the hell happend. is it a manual? try to bump start it if it is
Old 02-03-2009, 12:56 PM
Maness's Avatar
Yeah thats our next plan. Just a PITA when work isn't over until 430, I'm 30 miles from any shops, and I can't get anyone to help me push start until after work. Hah.
Old 02-03-2009, 01:06 PM
94civiccupew/b7's Avatar
sounds like your starter. when you do get to push start it and it does fire up, bout 90% sure it's prob your starter
Old 02-03-2009, 01:42 PM
Maness's Avatar
I'm not getting clicking or ANYTHING out of the starter.
Seriously seems like an electrical issue.
Old 02-03-2009, 02:09 PM
i just had a buddy that had the same exact thing happen to him in his focus. lights, radio, everything turned on but when he tried to start it, it wouldn't do anything. even tried to jump start it with my truck still nothing. come to find out it was his starter now it's fine. thats why i think it's prob your starter, but who knows maybe wiring . you can pull the starter out and have someone like napa or kragen test it to see if it's good or not to i think
Old 02-03-2009, 02:17 PM
andoxviii's Avatar
Are there any hills by your work? Try parking on a hill and use gravity
Old 02-03-2009, 02:19 PM
ALLDATAdiy INFO's Avatar
Have you checked fuse number 31 under the dash? Should be a 7.5 Amp fuse for the Starter Signal.
Old 02-03-2009, 02:24 PM
yeah that too
Old 02-03-2009, 02:32 PM
Maness's Avatar
No. Unfortunately car is in the gym parking lot, facing UP the incline of the parking lot. If we push-start going to have to roll it down to another end to get some room, haha. Going to suck.
Have NOT checked that dash fuse. I can check that but I suspect it won't be it. Thanks!!
More tomorrow...
Old 02-03-2009, 04:50 PM
green99civic's Avatar
Do you have good connect to your battery to your starter? is your starter unplugged the plug ins on the back of them often fall off very often at least i does with mine.
Old 02-03-2009, 07:36 PM
juston's Avatar
you should try switching your battery with your friends. it happend to me, my stero was on and everything but i tried jumping it to start, did not work. so we took out my battery and switched it with my friends. and my car started. then we switched the batterry back while the car was on and let it recharged and i haven't had a problem since. i tried push start, didn't WORK EITHER =[ SO YEA iono if u want to try it. its up to you. gl
Old 02-03-2009, 07:43 PM
haas480's Avatar
wiggle around you battery terminals. simple corrosion will only allow ample power to turn on lights, fuel pump, etc and now put enough power to the starter. look for a ground some where on the power wire to the starter and such. get a test light. easiest way to ever check anything. you can check power to fuses, starter, etc with a test light.
Old 02-04-2009, 12:52 PM
Maness's Avatar
Looks like it was a frayed wire on the starter.
Odd...
keithaustria
12-08-2010 10:30 AM
DC2_ALL MOTA
10-10-2006 01:31 PM
wreckedmyteg
04-20-2006 09:23 PM
WRTEG
11-23-2004 12:05 PM
junya16
03-01-2003 07:30 PM
Quick Reply: Car Won't Start Issue
