car wont start, code 0
I just converted my 91 b16 civic to obd1. Using a chipped p28 and obd1 dohc vtec dizzy with ecu jumper and obd0 plugs on distro.
Car is getting fuel but no spark. Getting a solid cel (code 0)...
I did a bunch of searching and some say its a bad chip / ecu. Others say they have a code0 and the car runs fine.
Could i have a code 0, and the computer would send fuel but no spark?
Re: (type Gendy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy »</TD></TR><TR><TD CLASS="quote">whats the solid cel saying though </TD></TR></TABLE>
ecu
ecu
Re: (ptran13)
Could i have a code 0, and the computer would send fuel but no spark? </TD></TR></TABLE>
Re: (type Gendy)
first off hold a test light to the negitive side of coil it should flash in time with the spark when you start it..if thats good i just finished putting a b16 in my del sol and i ran into that same issue. is there a solonoid clicking under the dash? if soo check your grounds one of my grounds ,the one on the trans to the body was not hooked up right and i have no spark as well i cleaned up the gronds and it started. the grounds to look for are ...trans to body,thermo housing and valvecover to body
Re: (SIR2DelSol)
yeah, everything else is fine. when i put the obd0 dizzy and ecu back in, starts fine, so i got no fuse, ground issues, etc
