car wont start...bogging..CEL *flashing*
I have a 96 hb with b18c1 swap...just put a new fuel pump in(Walbro 255) and car ran fine for a few days and tonight it starting bogging super bad and finally it died and wont start again...Im getting spark and I can hear fuel pump come on but it wont turn over. Any ideas would be greatly appreciated. Also I think O2 sensors are not wired correctly because Im throwing O2 codes and CEL was on prior to fuel pump install. My spark plugs also had oil on them .
Re: (JDMlyfestyle)
If the O2 sensor isnt wired up that wouldnt cause your car not to start. Check your fuses, mainly this one:
Does the car even crank or it doesnt even do that? Also oil on spark plugs is never a good sign. How old is the motor and where did you get it from? run a compression test.
Thats just all the stuff i would do off the top of my head. Hope that helps.
Mr. Badwrench
Re: car wont start...bogging..CEL *flashing* (ekfighter)
the check engine light flashing is a mifire related code. actually it is a catalyst harming failure. just if you needed toknow why it is flashing.
quad
20
03-14-2007 05:16 AM
dogbiscuit
16
10-28-2005 04:59 AM
