Car won't START
Old 11-07-2011, 09:27 PM
FLA$HY_5SiX2's Avatar
Default Car won't START
Recently i let my girl drive my car then she stalled outt on a hill & it wouldn't start up so i let it roll & popped the clutch but ever since then it wouldn't start up unless i did a push start a jump start wouldn't work . It doesn't crank or anything but the fuel pump turns on and when its running it's fine with no problem but when i turn it offf it doesn't start unless a push start anyone know the problem ?
Old 11-07-2011, 09:30 PM
Default Re: Car won't START
Some say the battery some say the alternator some say the starterrr but when i jst have the car on second click without it started all lights radio etc work finee & the battery is fairly new
Old 11-07-2011, 09:34 PM
Anyone help ?!?
Old 11-07-2011, 09:35 PM
Fliptard's Avatar
More info? Car, year, engine, recent upgrades.
Check battery connections, and all 3 grounds, check all fuses(under-dash and under hood) check battery and signal connections at starter.
Old 11-07-2011, 10:16 PM
Its a 93 ej1 with a b20v swap no recent upgrades i recently bought it & everything was fine would start up but would crank a few times in the cold i'm thinking it might be the startter ima go test the battery & how would i know if it's not the alternator
Old 11-08-2011, 02:13 AM
Chilloutdamn's Avatar
If the car runs fine once it is started then the alternator is fine. You can test the battery and alternator yourself with a multimeter. You should have like 11-12 volts at the battery with the car off and about 14 volts with the car on assuming the alternator is doing its job. If you have less than 10 volts with the car off replace your battery. If both alternator and battery test good, replace your starter.
Old 11-08-2011, 02:57 AM
First.EG's Avatar
check the rubber stopper on the clutch pedal. if you turn the key and you get no click most likey that will be your problem. if its that just glue a penny over the hole the rubber stopper was in.
NiKKa NiKKy
06-30-2022 09:59 PM
barnchips
07-19-2013 11:34 AM
lawlss
15
09-14-2009 10:23 PM
SwiftTypeR
01-03-2008 06:46 AM
ahcjar103
12-09-2001 11:37 PM
Quick Reply: Car won't START
