Car won't run
Need help.......!?!?!
Two weeks ago when i pulled my e-brake to park the car just shut off and won't run anymore. We figured out it is getting no fuel and no spark. We changed the distributor, checked all fuses, changed the ecu,does anyone have any idea wha the problem could be.?
Re: Need help.......!?!?! (Slamaccord)
checked all grounds and changed main relay...any other ideas?
Modified by silvestri51 at 2:23 PM 6/4/2006
Re: Need help.......!?!?! (SLATER97EX)
i have a security system but i disconnected that also and nothing hapend..would i have to pull more than just the fuse to disable it?
Re: Need help.......!?!?! (silvestri51)
Does your system disable the car if tripped? Or just make alot of noise?
If it disables the car, then that could be your problem. Yes completely disabling the system if the ignition relays through it would leave you dead in the water also. What kind of security system is it?
its a viper alarm, i pulled the fuse but that did absolutly nothing is there anything else that would disable it
ridin98civic
04-16-2007 10:02 PM
