Car wont move- Transmission?
Okay...so i got a new axle installed about a week ago.
Today im driving to work and put it in 3rd, all of a sudden the car wont move with throttle. The car will enter a gear, the revs and speed will rise, but the car wont move.
Theres about 140k on the clutch, but if it were the clutch the speed wouldnt rise due to the fact that the VSS is in the tranny, right? Im trying to think of what else it could be.
Re: Car wont move- Transmission?
no noise that i noticed, no smell
i got under the car and the axle is separated from the tranny at least a bit and fluid leaked out all over the place.
is this more likely a bad axle or an install error? I dont really even see how this could happen
yeah i would say so. the diff in the tranny must be spinning to move the speed sensor. So i would have to say check your axles it could be installed wrong.My bro did the same thing once and if i remember he had the same problem.
what he said if that secure pin doesnt go all the way in and secure it will come out the axle may look like its in there but its not all the way its just ur right side just take the tire off and the ball joint (upper) to get the axle out of the arm and slam it agaisnt the tranny to get it all the way in there ur clutch should be fine if it goes into gear trust me had this happened to be a year ago hehe im learning mechanics on my own by trial and error my car is my project :D
you dont even need to take anything apart. Just push the ****er back in until the axle all the way in. Even when you think its in give it one more good shove.
Sounds good. Thanks everyone. The guy that fixed it is on his way right now to fix it (since i have no tools at the moment). Is there any chance of differential damage (the splines in particular) due to this?
i wouldnt think so the only thing that that happened is that it poped out ur tranny was just moving but there was nothing to move if u get what i mean i was just saying to take out the upper ball joint so u can get a better grip at the cv and smack it in then try to pull it out it should pull out easy, if it does then its not installed right
dave1mcfly:
the best way to get an answer for your question would be to start a new thread, but if its not leaking then you don't have to replace it, but if it is i would say yes because you have to take out the transmission and flywheel to replace it.
Vietnamese!
leaking or not i still would replace it. You have the tranny out and for a few dollar more for a seal i would replace that sucker.
Seagull Management
To pop an axle back in on the side of the road you can use about a 4 foot piece of 2x4 or something similar to pry on the shock tower to pop the axle back into place, don't ask me how I know this.
Okay...so the guy who did the install came out and hammered it back in and the car drove fine....
downside.. its 2 days later and when im in neutral i can see the tach flipping out a bit (going up and down randomly independent of engine speed) indicating to me that the VSS is going nuts the same way it did before out the first time. Is it possible he just didnt push it in far enough AGAIN? Or could the axle falling out have screwed something up somehow? Maybe the axle is short, but he compared it with the old one so im not sure.
No, it was the tach. It was definitely bouncing around, or seemed to be, independently of engine speed. It was the same thing it did after the first time the axle was installed right before it came out.
hmmm the vss isnt connected to the tach..only the speedo. so say your at idle and the tach is just bouncing around all over the place??
Yeah, basically. it was going between 0-1500rpms. Maybe its bad wiring somewhere but it seems weird that it didnt start until after this axle install
thats proly the culprit...either its a lil short or the lil clip is gone. that still doesnt really explain the tach goin nuts tho. hmmm guess youll have to replace that axle and see if it goes away somehow
JaydMiKeY
07-03-2005 02:39 PM
IN VTEC
06-26-2003 10:14 PM
