Car Shuts Off When Giving Gas HELP PLZ
Old 03-08-2008, 05:28 AM
jnunez08's Avatar
Default Car Shuts Off When Giving Gas HELP PLZ
WAS UP Honda Tech I JUST GOT A 97 COUPE WITH A OBD-1 V-TEC RESON BEING IS BECAUSE THE OLD OWNER BLOW THE OBD-2 MOTOR THAT WAS IN IT OK SO NOW WHEN I TURN THE KEY THE CAR STARTS FINE IDELS GOOD AND ALL BUT THE MIN YOU GIVE IT GAS IT CUTS OFF ANY IDEA WHAT IT COD BE AND CAN IT BE FIXED ?
What Do I Do : ????????????
Cut Or Heated Springs Wich Ones Better ?
Old 03-08-2008, 05:33 AM
TougeCoupe's Avatar
when it comes to cutting or heating the springs i wouldn't do either your just gonna cost yourself money in the end.
Is the car throwing any codes
Old 03-08-2008, 05:36 AM
SirRevvs's Avatar
Default Re: Car Shuts Off When Giving Gas HELP PLZ (jnunez08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnunez08 &raquo;</TD></TR><TR><TD CLASS="quote">WAS UP Honda Tech I JUST GOT A 97 COUPE WITH A OBD-1 V-TEC RESON BEING IS BECAUSE THE OLD OWNER BLOW THE OBD-2 MOTOR THAT WAS IN IT OK SO NOW WHEN I TURN THE KEY THE CAR STARTS FINE IDELS GOOD AND ALL BUT THE MIN YOU GIVE IT GAS IT CUTS OFF ANY IDEA WHAT IT COD BE AND CAN IT BE FIXED ?
Check engine light on? Does it go off after a few seconds of turning the key to on position? If not check the code. Did you change out the oil pump to obd2?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnunez08 &raquo;</TD></TR><TR><TD CLASS="quote">Cut Or Heated Springs Wich Ones Better ?</TD></TR></TABLE>
Neither both ghetto, $30 ebay coilovers are better.
jnunez08's Avatar
How Do I Check For The Codes
Old 03-08-2008, 05:38 AM
jnunez08's Avatar
Default Re: (jnunez08)
no car stay of when i turn the key just fine dose not cut off its just when i press the gas it cuts off
SirRevvs's Avatar
top of this forum check the faq's. Here's alink because i ball like that.
https://honda-tech.com/zerothread/1901557
Old 03-08-2008, 05:44 AM
jnunez08's Avatar
Default Re: (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs &raquo;</TD></TR><TR><TD CLASS="quote">top of this forum check the faq's. Here's alink because i ball like that.
https://honda-tech.com/zerothread/1901557</TD></TR></TABLE>
thxs
Iamcj23
04-16-2008 10:15 PM
UCNTCME
03-28-2008 01:31 PM
1slwcoupe
12-22-2006 09:43 AM
dem0nk1d
12-17-2006 07:14 PM
LouisianaCivic97
09-27-2004 07:30 AM
Quick Reply: Car Shuts Off When Giving Gas HELP PLZ
