car runs like sh!t
car runs like ****
im guessins its a bad ecu or a bad obd1 conversion harness.timing fine. fuel pressure is fine. i got good vaccum.everything is grounded. only thing is im running greddy 310 on stock motor.i dont have stock ls injectors and my d16y8 injectors want work right in it i tried.any ideals. the motor is a b18b1 sitting in a 00 civic coupe. only mods is rods pistons and fuel pressure regulator. if that helps any
Re: car runs like **** (jdm.ej)
check O2 sensor. Also check the cat for clogs....sometimes they get clogged and they run like ****. Check that all first
Re: car runs like **** (hartandsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hartandsol »</TD></TR><TR><TD CLASS="quote">define "runs like ****"</TD></TR></TABLE>
not enough info
not enough info
Mr. Badwrench
Re: car runs like **** (IHateJDM)
where is your fuel pressure, find some stock injectors to use and see if thats the problem. i think 310's w/o engine management is a little too much.
Re: car runs like **** (boostedcivicsir)
barley stays idle if i push the clutch in while moving is shut off. it bogs in every gear when i try to take it past 3100. fuel psi is sat at 38. spark plug gap is fine. i got positive feed to the injectors timing is fine. i got all the sensors plugged. no clogged fuel line. i got good vacuum.im all out of ideal besided the fact it might be a fried ecu. i might be over looking something.
have you put a timing light on it? and i agree that the injectors are overkill, the stock injectors could run it properly, but i don't think that is your problem.
Electrician
Re: car runs like **** (Monochild)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Monochild »</TD></TR><TR><TD CLASS="quote">Drop a B18C1 in there then you'll be happy.</TD></TR></TABLE>
Oh yeah, great advice.
Re: car runs like **** (Dimitri_EG8 a.k.a. Dimi)
i wouldn't say my car runs and bogs...but i have a CEL for 10 and 43...being the IAT and fuel supply...if i let my car idle about 2 mins later it'll just die?? weird...it doesn't bog or anything...
i have a similar set-up being a b18b in a 98 hatch..with the conversion harness and pr4 ecu...i checked all wiring...all vaccums...all stock....everyhting is correct...but i still have my CEL...i think its your injectors..
Calvinator
07-30-2006 09:03 AM
