car runs like crap.
senior gold member
car runs like crap.
I'm getting a cel in my car. I tried hooking it up to the obd2 scanner and the scanner could connect to the ecu. then I tried the jumper method with no luck also. The car is running in safe mode. I tried changing the iac, coolant sensor, ecu. Does anybody have any ideas?
senior gold member
Re: (95b16hatch)
its getting spark. its just something is causing it to run in safe mode. I changed some sensors and its the same thing. When I took out the b18b everything was running smooth. now when I threw in the lsvtec its when this starting happening.
senior gold member
Re: (rathead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead »</TD></TR><TR><TD CLASS="quote">is it running realy rich? spitting and sputtering out the tailpipe?</TD></TR></TABLE>yeah its running rich. don't they all when its in safe mode?
Re: (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote">yeah its running rich. don't they all when its in safe mode?</TD></TR></TABLE>
is it real rich? it sounds like you have something crossed. if the car(or computer) is not obd2 then a scanner wont tell you ****, if your jumping it and still no codes, its for sure a connector switched or the jumper is fucked. this car is obd2 with a jumper right?
Re: (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan »</TD></TR><TR><TD CLASS="quote">yeah I'm running a jumper. what do you mean by some connector crossed?</TD></TR></TABLE>
map and tps could be crossed.
