Car not starting after installing a CD player
Old 04-20-2006, 11:35 AM
desiaashik's Avatar
Default Car not starting after installing a CD player
93 Honda civic EX 1.6L
I was installing a CD player this past weekend. The issue was that comes out of car and the ones from CD player had different color codes which made it impossible for me to figure out which one is the right wire. I tried trial and error method and after 3 hrs of fun times, the CD player started.
The real problem lies here. After I installed the CD player, I was ready to go out and the car never started. I thought maybe the batter was dead. I jumped the battery but still the car never started.
Then I checked the distributor and noticed that there was no spark going to spark plugs. I change the whole distributor but couldn't resolve my initial problem. The car still won't start. I gave it to one of my mechanic and he tried for two days but no help from him. He also tried swapping the coil.
Can anybody help me to understand that how installing a CD player screws up the starting of a car. I still can't understand. I am thinking that maybe something got shorted while I was doing my trial and error to make CD player work.
PLEASE HELP !!!!!
Old 04-20-2006, 11:39 AM
be professional
Targa250R's Avatar
Default Re: Car not starting after installing a CD player (desiaashik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by desiaashik &raquo;</TD></TR><TR><TD CLASS="quote">The issue was that comes out of car and the ones from CD player had different color codes which made it impossible for me to figure out which one is the right wire. I tried trial and error method and after 3 hrs of fun times, the CD player started.</TD></TR></TABLE>
Good grief, are you an idiot? Haven't you ever heard of a wiring diagram?
http://www.installdr.com/Insta...7.pdf
Now go wire it up properly, and check all your fuses to make sure you didn't blow one.
Old 04-20-2006, 11:44 AM
Turbo_y8's Avatar
Default Re: Car not starting after installing a CD player (Targa250R)
wow, ^^^ what he said
Old 04-20-2006, 11:48 AM
desiaashik's Avatar
I never had wire harness that goes between the wires from car and the CD player. I also checked all the fuses and they all the fine. The CD player works, its just the car doesn't start anymore.
Old 04-20-2006, 11:51 AM
the jdmchop's Avatar
well des it crank and no start?
main relay?
Old 04-20-2006, 11:54 AM
desiaashik's Avatar
Default Re: Car not starting after installing a CD player (jdmchop)
It does crank but no start.
If it is main relay, where is it located? It's definitely not in one of the fuse box underneath the hood.
Old 04-20-2006, 11:56 AM
do you hear a click noise when you turn the key?
Old 04-20-2006, 11:59 AM
desiaashik's Avatar
Yes, I do hear the clicking sound when I turn the key.
Old 04-20-2006, 12:09 PM
civic_driver's Avatar
i would try a brand new battery and return it if it still doesn't start...
you are supposed to remove all electrical power when you are doing this type of work so that even if you short something while you work, it won't cause problems like this..
that's why there are people other who charge money to do this type of things because they know how to do it
Old 04-20-2006, 12:40 PM
manntis's Avatar
I did this by accident years ago while installing a CD player into my at-the-time g/f's '93 civic.
Turns out I just blew a fuse. I checked the fusebox in the dash, found the culprit, swapped it,, and the car was good to go.
Old 04-20-2006, 12:44 PM
ZipTieGUy's Avatar
you are an idiot foreals. if you have no harness you shoulda connected a harness. it may night even be installed correctly(left and right speakers might be mixed uip).
and you go and change out your whole distributor then ask for help?
common man if it happen right after the cd player install you know the install fucked something up. a dizzy doesnt go out right after you put in a deck. you probly blew a fuse
Old 04-20-2006, 09:27 PM
Turbo_y8's Avatar
Default Re: (ZipTieGUy)
sounds crazy, but hows your gas situation
Old 04-20-2006, 10:20 PM
FalkenSiR's Avatar
Default Re: (tuck'd98)
You blew an ignition or Fuel-related fuse. That simple.
thunderboy
Honda Civic (2006 - 2015)
07-13-2010 04:01 AM
Mushvroom
Audio / Security / Video
06-02-2005 08:48 AM
BadEH2
10-24-2004 06:34 PM
khny83
09-14-2002 09:44 PM
Quick Reply: Car not starting after installing a CD player
