car leaking anti freeze from under car...?????????????????WTF....
Old 05-28-2005, 05:57 PM
VRD^don's Avatar
Default car leaking anti freeze from under car...?????????????????WTF....
okay car is a 94 delsol..bought it as a chassis..just finished installling 00y8 motor in to it and now after the install, and fillled with liquids the car started leaking from under the chasis...also the car threw codes 21 and 9....need help guys...what can cause the leakage. and the cels...thanks
Old 05-28-2005, 06:04 PM
neutron91's Avatar
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (sohc_Vtec)
i hate it when people ask where leaks are coming from when there is visible leakage on the ground... just freakin look ... more than likely a hose, water pump, or somethin of that nature... code 21= vtec solenoid... code 9= cylinder position sensor (inside dizzy)
Old 05-28-2005, 06:05 PM
mp5o's Avatar
Does is start? CHeck ALL your coolant lines and make sure they're all going to the right place. I fucked mine up one time and had coolant coming out of my exhaust.
philosofy1's Avatar
start your engine and look around to try to see if you can find your leak, double check all hoses, also check around the radiator or water pump
Old 05-28-2005, 06:10 PM
grafffeener's Avatar
i would check all hose clamps those things are known for going bad.
Old 05-28-2005, 06:12 PM
Cuong-nutz's Avatar
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (philosofy1)
check radiator inlet and outlet, both ends
dont' forget the heater hoses that go into the firewall. There's the water pump, and the coolant lines that got to the IACV and on the intake manifold into the head.
Old 05-28-2005, 06:35 PM
pennies_hatchie's Avatar
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">i hate it when people ask where leaks are coming from when there is visible leakage on the ground... just freakin look ... more than likely a hose, water pump, or somethin of that nature... code 21= vtec solenoid... code 9= cylinder position sensor (inside dizzy)</TD></TR></TABLE>
not too concern about the CEL, but the major concern is the anitfreeze leak. ITS NOT COMING FROM THE ENGINE BAY (got that figure out). for some reason, its coming out of the holes underneath the chasis (where the tar is) ..go look under your car kind of by the sideskirts and you know what i mean. it comes out (dripping in some and gushing out in other holes) all along the sides (front all the way to the back of the car), sometimes even out of the side of the sideskirts. i bought the car as a shell so im unaware of anything wrong. as far as looks go, nothing seems to be out of place. also, there was smoke coming out of the dash as well. lmk.
Old 05-28-2005, 07:28 PM
we're thinking its the heater core (i just found out the heater motor doesnt work..no fan..nothing) but the carpet is not wet at all, but all the antifreeze is leaking out from those holes under the chasis
Old 05-28-2005, 07:43 PM
Status Sean's Avatar
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (pennies_hatchie)
could be that !
Old 05-29-2005, 07:15 AM
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (rw92civic)
ttt
Old 05-29-2005, 09:56 AM
VRD^sam's Avatar
ttt
Old 05-29-2005, 07:59 PM
Hurricane's Avatar
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (ef9turbohatch)
Are there channels in the floor pan that might let coolant escape (without getting the carpet wet) from the sides if the heater core leaked ?
Weird
Old 06-03-2005, 09:43 AM
VRD^don's Avatar
Default Re: car leaking anti freeze from under car...?????????????????WTF.... (Hurricane)
SOLVED....coolant was leaking from the heat hose..tube was bent...
rags00prelude22
03-12-2012 09:32 AM
Honda_wannabe
03-09-2010 03:40 AM
JDM_HAMSTER
06-26-2008 01:55 AM
isaacEK
08-28-2007 01:16 PM
Brian-Brian
06-20-2003 03:04 PM
Quick Reply: car leaking anti freeze from under car...?????????????????WTF....
